Flu419 loader to fit a u500
tatra813
25
Washougal Wa
I picked up loader assembly off of a flu419. I need to do some fab work to make it fit on the front hitch of my u500. U500 attachments have these triangle weld on claws that insert into the top of the trucks front hitch. Anyone know where I could buy some of these weld on claws? Is there a Schmidt rep in the USA? I could call?
I also want to pull the bucket off of the front of the loader and buy or fab a plate that converts the loader to a skid steer quick tach setup. I found some companies that make conversion plates from the loader style to skid steer . With it being a Schmidt loader does anyone know if the front is a universal type style or is it unique to the see loader. I’m talking about the attachment points that attach to the bucket. For other tractors they make plates that convert it to skid steer style.. I would much rather buy a ready made conversion plate if there is on out there.
appreciate any help. I’m also looking or a hydraulic winch or 2.
Speedwoble
296
New Holland, PA
Persistence pays off!
They are apparently called Anbauplate claw, there is a post on Benzworld talking about where to get them and the styles.
I have the attachment points that bolted to the frame of the FLU if that helps.image.jpg
Regarding the skid steer attachment, there is a company in Lena WI selling Flu’s on eBay that makes an adapter. It has been on my list to make one, but it will not be in the next few weeks.
As far as I know, it is not a standard. In fact, since the top and bottom pivot pins are offset, that seems to be different than most of the loaders on the market.
SpoiledSpud
Northern (ID/WI)
Have you looked at the Hauer loader engineer to fit the U500?
tatra813
25
Washougal Wa
Tha
I have the attachment points that bolted to the frame of the FLU if that helps.View attachment 810929
Thanks for the info I’ll look up the claw
If you remember the name of the company who makes the adapter let me know
Thank you
The FLU farm
1,227
The actual midwest, NM.
I haven't measured, or tried anything yet, but it sure looks like what's on the front of my "new" MB4/94 has the FLU style mounts bolted on there in addition to the plate with the triangles.
For the quick tach plate conversion I used a setup from palletforks.com.
tatra813
25
Washougal Wa
fo you want to sell those brackets?
tatra813
25
Washougal Wa
Thanks. You got any more info on that ?
tatra813
25
Washougal Wa
W
ould you like to sell those brackets in your pic?
tatra813
25
Washougal Wa
Any idea where I could buy the triangle claws?
anbauplate claws?
Speedwoble
296
New Holland, PA
.....Anbauplate claw, there is a post on Benzworld talking about where to get them and the styles.
....Regarding the skid steer attachment, there is a company in Lena WI selling Flu’s on eBay that makes an adapter....
Search for Anbauplate claw. For me the first result is the post on Benzworld saying where to get them.
I am not allowed to link to an eBay auction, so you will need to go to eBay, find the FLU for sale with the loader adapter and contact that seller.
Flu Farm made a post detailing his adapter and another fellow has a video on YouTube making his adapter. Try searching for them.
Yes, I will sell the mounting brackets from my parts pile. Message me.
tatra813
25
Washougal Wa
Those are not what you need to mount a SEE loader, if I understand this even halfway correctly.
What you need has two large pins at the top and two blocks with holes for bolts at the bottom.
Yes I’m aware. I need the See frame brackets to use the See front end loader. Then Ill weld a plate on the SEE brackets . Then that plate needs to mount on my u500 front plate which requires the triangle claws for it to work. Hence why I need to find the weld on claws. Hopefully that made sense
The FLU farm
1,227
It did make sense...except, I don't know if the claw setup is strong enough for loader use.
On my 4/94 the two systems are completely separate, bolted on to the same frame obviously.
tatra813
25
Washougal Wa
Ill PM you. For everyone else you can buy the quick connect that converts the SEE loader to a skid steer quick connect hitch. The kit also comes with a skid steer receiver bracket to weld on the bucket its $1900 from d and B construction equipment. 800-567-3168
The FLU farm
1,227
Ouch! That's about four times more than it costs to do it yourself.
Or maybe about the same cost if you need to buy a good MIG welder, too, which is reusable.
tatra813
25
Washougal Wa
Depends on your situation I guess. My ROI of my time makes it cheaper and I have a full fab shop. I also have a skid steer with tons of attatchments, the u500 has plenty of flow for my attatchments. Plus the one attatchment I needed was a tooth bucket for my skid steer so Ill get that too........win win for me
SpoiledSpud
Northern (ID/WI)
Please post photos. We enjoy seeing projects develop.
tatra813
25
Washougal Wa
Ok I found the claws available on the shelf in america
$133 ea
Washington auto carriage
hope this helps someone else. Or look at the drawing I posted above and have a fab shop make it. But doubt it will be much less
