Front end rebuild
HelluvaEngineer
78
Atlanta, GA
My M1009 front end is getting dangerously bad, quickly. I went around a big turn yesterday nearly went off the road. I had to dial in a lot more steering and then the wheel was off-center for a while until things settled down. It felt like it was dog legging for a bit.
Rather than debug individual components, I'm considering replacing all the steering components. I spent some time looking up parts last night and it looks like there is a wide range of prices, from what I assume is cheap Chinese junk to what pricy, probably slightly better, Chinese stuff. I was hoping MOOG sells an entire kit, but unfortunately it looks like they only have them for other trucks.
A couple of questions:
  1. Does anyone have a suggestion on certain brands for the components? Does anyone sell a complete kit?
  2. I believe my date of mfr. was 1984. Do all parts match a 1984 K5 Blazer?
  3. What size castle nut socket do I need?
  4. Any tips or tricks? I'm going to have to do this in my driveway. Warn me if that's a terrible idea and I should try to find a front-end shop.
Thanks for the help.
GopherHill
1,206
Thomaston, TX
I've always tried to use Moog. I've used TRW and Delco products with good results. Your truck is older and complete kits are probably not packaged. I go to the local independent parts house and ask them to fix me up.
Best of luck to you, a worthwhile endeavor.
adf5565
647
Tioga, PA
So far I’ve had good luck with Moog. But I’m sure any reputable brand is fine. I definitely agree with changing everything at once, I’ve done that on my m1008 as well as other vehicles and then typically you never have to worry again. I’d suggest going to rock auto at least to see what parts/brands are available, it’s easy to search and then you can use the part numbers to buy it elsewhere if needed. I didn’t see a complete front end kit on there but at least all the parts are individually.
DIVE DIVE
778
Chesapeake, VA
I don’t have an M1009 any more, but when it comes to steering components I would only buy MOOG parts. You can get any other Chinese crap from any parts house with a lifetime warranty but when the warranty is followed up by a 80-100 dollar alignment it pretty much is a waste of money. Do it once and do it right. If you aren’t running a lift or over-size tires then you’ll be good for a long, long time. Keep everything lubed. Good luck.
nyoffroad
663
Rochester NY
If it's not your daily driver I like to order from Rock Auto, they have parts listed from the cheap and scrolling down they get better and more$ but it's tough beating their prices. The only issue is if you get the wrong part, I did have that happen ONCE but that was just an A/C line.
It's nice doing it all at once and not have to worry about this or that every year. While at it toss in new shocks and brake pads.
All parts are for a 1984 Chevy Blazer and if asked with a 6.2L of course.
Barrman
1,653
Giddings, Texas
Check your rag joint as well. Something caused your steering wheel to now be off center. Rag joint or axle U bolt is my first 2 thoughts. Front end parts normally don’t suddenly go bad. If that is what really happened something broke or bent in that turn. Check the frame around the steering box bolts as well. The frame is known to crack there which would cause the box to shift and make your steering wheel off.
WWRD99
1,442
York Pa
I like to look in the TM and get part numbers and nsn from that then search those out. What I find is NOS parts from surplus companies out there that don't charge much at all plus you usually get American made parts. They will be old but not used so they'll work perfect.
87cr250r
1,923
Rodeo, Ca
OEM parts are almost always best. Be weary chassis components with zerk fittings. These are problematic because the correct lubricants for modernish vehicle suspensions are NOT available at the parts store and are typically very expensive to purchase. The rubber seals and components used in relatively modern suspension components are damaged by petroleum greases. These items will typically suffer a very short life not of their own fault.
ssdvc
639
CT
Check to make sure your steering box is bolted up to the frame correctly and that there are no cracks in the frame. I would do that before I start ordering parts.
HelluvaEngineer
78
Atlanta, GA
Thanks. I'll check the rag joint. This has happened before. I was under the truck last night and confirmed no frame cracks. I'll weld in a reinforcement plate at some point.
HelluvaEngineer
78
Atlanta, GA
OK, thanks. I came back to ask about that. I've been searching old posts and couldn't get that answer. I see that the diff is an open 10-bolt, but I'm not sure which "civilian" version to target. As an example, look at this site:
They list multiple front end options. I'm hoping the answer is Dana 44 compatible parts because I'm about to go on a MOOG buying spree and those appear to be readily available. Those Spicer u-joints look identical to what's installed now.
I will jack the truck up tomorrow and start wiggling stuff in an attempt to locate the issue. It feels like the tires are toe-ing out on me periodically. Braking is scary.
nyoffroad
663
Rochester NY
The list multiple front end options. I'm hoping the answer is Dana 44 compatible parts because I'm about to go on a MOOG buying spree and those appear to be readily available. Those Spicer u-joints look identical to what's installed now.
I wish I could say for sure but I don't think it's the 44. Look at the cover and compare, It's been awhile but I believe I had the 8.5 30 or 32(?) spline
HelluvaEngineer
78
Atlanta, GA
We had some better weather today so I finally got under the truck and looked around more closely. I also jacked up the front and tried to "wiggle" the wheel assembly as best as I could. Also put a bar under the tires and looked for loose ball joints. Everything was fairly tight except I think the L wheel bearing has a little play.
I was also looking at the position of the tires yesterday and it looked like they were in different locations in the wheel well. This concerned me because I recently paid a local shop to install a 2" lift kit, mostly just to replace the badly sagging springs.. It occurred to me that they may have not bothered to make sure the axles are parallel. I measured as best as I could from the U Clamps to the front chassis attachment bolt centers. The rear looked spot on (I think the transmission shop just angled the diff up at bit and they may have checked it.0 The front however was pointed to the left with a difference of about 1/4". I don't know how big of a deal this is.
The only thing that concerned me was the L front spring. the lowest leaf has moved out of position. I think at this point I'd like to find a shop that can check the torque on all the leafs and also do a proper 4 wheel alignment. This probably won't be easy. The shop I normally use for alignments refuses to set anything but the toe on these old trucks. Does anyone have suggestions on next steps or locating a service shop that will check the axle alignment? Maybe a heavy truck shop?
Barrman
1,653
Giddings, Texas
That leaf spring plate movement makes me wonder if your U bolts are tight. With the engine running have someone turn the wheel lock to lock while you watch the axle at the leaf spring. The drivers side because of the steering linkage geometry will walk front to back as the wheel is turned. Doing this on clean concrete works best.
HelluvaEngineer
78
Atlanta, GA
Made me wonder too. This afternoon I got a chance to break out some tools and get under the thing. It looks like the "Jeep shop" that installed the springs torqued one side, took a smoke break, then did something else. The driver's side was totally loose. Good thing the sway bar kinda sorta located the axle or I could be dead now.
I have a parts shop putting together a list of standard service parts for the front end. I'm going to go through everything and get those axles squared off too (and torqued properly.) Thanks to everyone for all the advice. I love this forum.
121
Metairie, LA
Did you ever find a good shop? I actually am now in the Atlanta area, and have
have a similar issue. I would like to just replace the springs entirely really.
