fun at grayling
wilco
newross, in
Fun at Camp Grayling! Kuble wagon stuck in the sand. Deuce no problem! Lots of wheel hop on thesteep hills. To much tire psi or ??
1stDeuce
15
Farmington, NM
Yup, too much air pressure leads to hopping in the sand, whether it's a deuce or a pickup. Read the dash plate, it gives good suggestions for tire pressures. I run the fronts a little higher than the rears, but you need to get them down from road pressure, so that you can see the sidewall deform some.
Is your deuce on 9's or 11's?? (I see it's singled... nice!!)
C
1stDeuce
15
Farmington, NM
Sweet! I have some M34 wheels that I'm in the process of painting, then I have some new 11.00's that are going on. Should look very nice!! (Thus requiring me to paint the entire deuce, I'm sure...)
Wish I was having fun there too!!!
C
DeuceNewb
Wilmington, NC
ahh, you're singled in the rear....that adds a little to the problem. when i'm in sand, i leave the rear alone(too lazy, plus the 8 tires are enough flotation) and drop the front to 35....never had any problems.
