- 15,921
- 22,227
- 113
- Burgkunstadt, Germany
What plug?
I can't find a plug for less than 500 bucks. Ouch
Thanks I will watch for that’s. It maybe getting some use in the next couple of days around here. I dodge the last outage Kurt aka kloppk lives a miles away and was not quite as lucky. But prepared for sure.The system which powers the aux fuel pump has a low level turn on, and high level shutoff. 1/2 a tank won't activate either. If you get below a quarter tank, you will hear it kick on at some point, in the PRIME + AUX setting. I don't recall the exact level (it can actually be manipulated, by changing the installed height of the double float switch in the tank if one wanted it to refill sooner than later). Where its set from the factory is very suitable though.
Test it out.Thanks I will watch for that’s. It maybe getting some use in the next couple of days around here. I dodge the last outage Kurt aka kloppk lives a miles away and was not quite as lucky. But prepared for sure.
