Generator wiring
Dead pilot
135
Fallbrook, CA
So my deuce was missing the gen when I got her. But recently I got my hands on a gen that was off a m35a2 but the problem I'm having is my truck has the a plug with 3 holes and this gen doesn't have a plug it has 3 places to connect wires to post. How can I remove the plug and make sure I get the wiring right
Sent from my SM-G930V using Tapatalk
NDT
5,918
Camp Wood/LC, TX
You need the alternator conversion kit. Call around to TJMurray etc, the vendors should have some.
jbayer
St. Aug., FL/ McGrady, NC
What NDT said.
Search for this:
Military M Series Generator to Alternator Conversion Kit 25 to 60 Amp
military Kit NSN 2990-00-000-0088
This kit is all you need to convert your OEM harness to the higher capacity Alternator that was utilized by the military as part of the required materials to retrofit their vehicles.
the NSN description is as follows:
Characteristics Data Response for NSN 2920-00-000-0088
ITEM NAME INSTALLATION KIT AL, AGAV 60 AMP;
IDENTIFICATION 2320000771636
ITEM DESCRIPTION:
CONSISTS OF 2 BRACKETS; 5 CLAMPS; 1 HARNESS; 2 CABLES;
1 CONNECTOR; 1 STRAP; 3 WASHERS; 2 NUTS
