- 32
- 7
- 8
- California
HDT NORDIC GL0593ZAADWFX21 USMC EEECU 5-TON UNUSED BUILT AND TESTED IN 2018 , THIS MODEL IS STILL IN ACTIVE USE BY ALL BRANCHES OF US MILITARY .
USES R-410 A FREON WHICH IS ALREADY CHARGED AT FACTORY HAS 1 HOUR OF TESTING TIME FROM FACTORY ON HOUR METER
COMPLETLY BUILT FROM ALUMINUM HAS FORK POCKETS AND LIFTING LUGS
EQUIPPED WIUTH SOFT START
HAS 2-SPEED BALDOR FAN MOTORS
2-STAGE COPELAND COMPRESSOR
PRICE IS $ 3950.00 LOCATED IN OAK HILLS CA
TEMP AND PRESSURES CAN BE TESTED WITH A SIMPLE MULTIMETER
EPOXY COATED EVAPORATOR WITH TUBULAR HEAT STRIPS WILL RUN AT 10 DEGREES OFF LEVEL IN ANY ENVIROMENT SIGHT GLASS ON EXTERIOR FULL REMOTE WITH CORD INLET AND SUPPLY DUCTS IN TOP OF MACHINE EVERYTHING NEEDED TO CONNECT FULLY DIGITAL MONITORING SYSTEM .PERFECT FOR ANY LOCATION REMOTE OFF 15 K GENSET OR SHORE POWER 208VAC 3 PHASE 60 HERTZ OR USE WITH INVERTER . USE IT ON HOME, SHOP, TENT , TRAILER, OR ANYWHERE NEEDING HEAT OR AIR COND . US MILITARY PAYS $42,000 FOR THESE UNITS AND THEY HAVE A CURRENT ORDER IN FOR MORE AT THIS TIME. WILL RUN TO -50
