Heater core replacement? M925a2.
ger84
15
Clinton, NJ
Hi gang- Read a lot of threads however nobody says where they got a new heater core from. I saw one person say “#398010” however there is modifications for the side and cut etc. also the “Murray #398010” does not have a valve on the side of it…. Just want it to fit. Called 2 radiator places in nj and they said they don’t do brass! I gotta be missing something. Any recommendations I am all ears. Thanks in advance.
Superthermal
778
Utah, Murray, United States
I replaced mine with an aluminum one that was a bit different. Works fine. Ended up mounting it with some nice felt around the outside of it and press fitted it into a comfy bed in the housing with about the same angle as you see here.
juanprado
2,762
Metairie/La (N'awlins)
This core is made by hunter not amg.
In their infinite wisdom the whole assembly is replaced and Uncle Sugar doles out green. Heater core is not a field replaceable item. Can be ordered from hunter but it is outrageously overpriced
The bleeder valve is nice but not critical.
Many threads on here. Search for alternative automotive core to substitute or keep searching for a real radiator shop.
Someone has to service hd ,trucking, and construction companies. Look for older guys, young ones don't have a clue.
ger84
15
Clinton, NJ
Yeah I have seen online that ppl just replaced the whole thing.... unreal... agreed- thanks for the input. have not found a good fit alternative with out modifications. going to call around tomorrow for hopefully a price to fix the heater core and if all else fails eastern surplus has one... (seen above in top post)-
ericp351
68
erie Pa
I did mine with a (this web site recommended) one for an 1980's Fox (think small LTD, Mustang, etc) Ford. Was in stock and affordable. Required only the slightest of modifications. A bit smaller and alluminum, but you will never notice..... I THINK, buy without AC Option, but your parts guy will match up.
ger84
15
Clinton, NJ
Ok so I made a mistake. Tried looking at the Tm’s but anyone can help me and tell me which hose goes where. I took off and my picture doesn’t show. Dummy me. Thanks
