help identifing an air pack
Big Mike's Motor Pool
i recently got ahold of a brand new airpack. i was wondering if anyone could tell me if it will work on my deuce or not. it looks different than my current air pack. its a bit shorter where the can is but looks the same the rest of the way.
i pulled some numbers from it, they read as follows.
19207 12368255
06721 176 03 T
MFR-N4105AH
if it will fit my 71 M35A2 then i plan on keepin it on the shelf, if it wont and somebody can use it let me know.
Floridianson
2,472
Interlachen Fl.
Yes it will fit the Deuce. The only differance is the way you will oil the pack. Just take off the tube at the one end and the outher will be a o ring. Leave the o ring side in and rotate the tube so you can fill it with oil and try and spin it back around without getting to much oil on your self. Tighten her up and apply the brakes a couple of times to work the oil in and around. Smart thing here is to oil before install?
number9
Lexington, KY
If the knowledge I have learned here is correct - and my memory correct, that is the newer style 'short' air pack and I don't think there are any rebuild kits available for it. I know I have read the older kits won't work for it.
