HMMWV fan clutch conversion?
1crook
Bethlehem, GA
I have a new Borg Warner viscous fan clutch. Both the NSN (2930-01-565-8355) and the BW part number (1210-09-167-51) come back as HMMWV, on various websites.
But all the HMMWV fan clutches I see in the HMMWV TMs (-P) show as being a hydraulic clutch.
Does anyone have knowledge of this item? Is this a later service replacement designed to replace the hydraulic setup?
Dawn
Hummermark
31
London uk
Hi used with the gear driven fan (GDF) serial number 300k and above in theory.they do away with the hydraulic clutch and have the GDF
do you want to sell one?
1crook
Bethlehem, GA
Is this fan clutch all that is required to convert one? Are there any other components that are necessary, like for instance are the fan blades the same?
I have someone that is interested in it, but could not find a lot of information on it.
Hummermark
31
London uk
Hi there is quite a lot to get to convert it to gfd the fan is different need new chassis crossmembers,different mounts for the front diff,new mount for the radiator,GDF,drive shaft,engine crankshaft pulley,radiator cowling and re route some small pipe work.A fair job
1crook
Bethlehem, GA
Thank you for the reply Hummermark. I will follow up with my customer and see if he is still interested based upon the additional items needed to make this work and let you know if he does not buy it. You will get first shot at it since you expressed interest first.
Dawn
