Hummer Guy
- 703
- 93
- United States Louisiana
Does anyone know if the injectors off a turbo 6.5 would fit right on my non turbo 02 6.5?
Got it, I'm looking at some on ebay, it says its from China, I know China products are not so great, but I figure something as simple as injectors shouldn't matterThey sure do, dimensions of the body are identical.
no, you cannot use turbo injectors on an NA motor…and why the hell would you put some Chicomm crap injectors in when you can buy OEM? and yes…there is a quality difference.Got it, I'm looking at some on ebay, it says its from China, I know China products are not so great, but I figure something as simple as injectors shouldn't matter
Do you know where I can find the OEM ones for the NA Motor? I been looking and just see the turbo injectors mostlyno, you cannot use turbo injectors on an NA motor…and why the hell would you put some Chicomm crap injectors in when you can buy OEM? and yes…there is a quality difference.
Mind explaining why? Only thing I know is different is the pop pressure. (126bar for the N/A vs. 142bar for the turbo version).no, you cannot use turbo injectors on an NA motor…
Correct, and That pop pressure is absolutely crucial to the engine running correctly.Mind explaining why? Only thing I know is different is the pop pressure. (126bar for the N/A vs. 142bar for the turbo version).
Well, PP does affect fuel atomization, yes (not flow, as some might think). But IDK about it being as much as "crucial"... (?)That pop pressure is absolutely crucial to the engine running correctly.
It is just logic that their NSN is different, but Bosch for example uses the same part numbers for the body AND the tip, for both 6.5L versions.If the 2 engines used the same the injector, they wouldnt make 2 different injector per the TM, the UOC
is specific.
