Humvee Led front and rear light conversion
Duff ace
FL
I just get these in the mail today for my Humvee. Plan to install them tomorrow morning. I don't see instructions.
Do unscrew the lights around the housings or find the bolts behind the units? I couldn't find anything on YouTube for a reference
Sent from my SM-N960U using Tapatalk
simp5782
Feo, Fuerte y Formal
9,317
Mason, TN
If you have the buckets on the lights like it appears you do your old lights will have the two rear bolts to bolt those on for the turn and tail buckets.
Hopefully you did not pay that much for those lights though.
Duff ace
FL
So it's just the bolts in the back then. The new ones are full casings like the oem ones.
No I did not pay that price
TOBASH
3,143
Brooklyn, NY
The lights look good.
When you post with TAPATALK the pics disappear. That is why it is against TOS.
Please consider properly uploading the pics to the site so they don't disappear in the future.
Ejoy your new visibility and ability to see at night.
Duff ace
FL
Didn't know that. Thank you
I installed the rear leds yesterday (pita! with rusted bolts) still can't get some bolts off and will probably end up taking to a shop.
After the install, the left blinker is not working. It was pretty much a plug and play system. Neither the front or rear left are working and the light near the steering wheel seems less lit when I turn the left blinker on vs the right one. The front and rear right blinker are working after the install though.
Thoughts?
therooster2001
Colorado
Unless the bulbs are flat out DOA, you're probably chasing a ground issue. Test the bulbs from known working on the other side just to be sure, then check your grounds (and feeds) with a multimeter. I've also seen Packard connectors go in a bit sideways and not make a great connection and cause some low light situations (that's how previous owner left one headlight on mine) so check that they went in perfectly. If that's not it, it's your blinker box (probably not).
And for the rusted hardware, don't take it to a shop, there's nothing that advice, heat, penetrating oil or a cutoff won't fix with these little parts.
simp5782
9,317
Mason, TN
Take the bulb out of the turn signal indicator on the turn signal. Its not an LED bulb so it interferes with the flasher
Mixing led and regular bulbs can cause issues. Especially if you don't have an LED flasher
TOBASH
3,143
Brooklyn, NY
When swapping in LED bulbs, the linker assembly can have issues. First and easiest is to remove the green cap in the Nartron Signal Controler (the flasher at the left side of steering wheel), and remove the bulb. Replace only with LED bulb.
After that, there might be issues with the flasher relay unit requiring change to a newer unit or rebuilding using parts sold on Amazin of FleaBray.
I included a good thread on how to rebuild flasher relay, to also allow LED use, IF YOUR RELAY ISN'T COMPATIBLE WITH LED.
https://www.steelsoldiers.com/showthread.php?132184-Economical-turn-signal-flasher-repair-option
Stonewall
Peoria, IL
LED for headlights is obviously a great idea. LED's for all the other lights (marker, turn, stop, parking, etc) does not really seem to provide much benefit, for all the potential problems it creates. The standard bulbs are cheap, and most likely last longer than any of us will ever need.
JoeJrTheBarber
19
Chicago, IL
LED's are far superior to the glass type bulbs they have replaced.
LED's come on / react faster then a standard glass style bulb. In a brake light application this could prevent a accident. Thus why all auto manfs. use some sort of LED lighting in their cars. Less power consumption, faster reaction times, longer life, brighter, and are not effected by vibration / heat / etc...
