- 6,848
- 664
- 113
- Stratford/Connecticut
I have a bank of hyd controls. One control does not function. The arm moves like the others but does not have the same feel as the others in operation. The other controls that work you can feel the hyd flow as you are operating them. When you operate a working control the arm on the non working valve bounces a little. Before I start taking it all apart maybe someone can chime in. Can the valve piston piece just be stuck and the hand control will still operate? The bad is directly below in the pic. It is weeping some hyd fluid. The TM has all mil part numbers not the normal civ parker numbers. So being able to rebuild this one would be ideal.
Thanks
Will
Thanks
Will
