- 12,196
- 315
- 0
- gainesville, ga.
When I had my 48 Mack tractor, I installed a power steering set up that came off a old FORD dump truck, about a 3t or 4t or so, the pump just mounts as any pump but the cylinder attached to the frame and to the tie rod, the cylinder had a sensing valve that pick up the tie rod movement and allowed the cylinder to pull/push the tie rod. After the install the steering went from arm strong to one hand . It took more time making the pump mounts for the 220 then it did for the install. drill a hole or two in the frame, CLAMP to the tie rod, run hoses, adjust valve. done
