Inexpensive camper/utiliy box for m35a2
718
9
Springfield Or
Finished up everything necessary to go camping.
20141012_124628.jpg20141007_181836.jpg20141008_132114.jpg20141008_132118.jpg20141012_124750.jpg20141006_122908.jpg20141010_133327.jpg20141010_133320.jpg
Only had one problem. The water pipes pulled out of the shower faucet. It appears that the plastic it is made out of is not pvc so I got no chemical bond. I made a temporary fix with a mechanical bond. A block of wood jammed behind the pipes. No leaks and allowed us to take hot showers. Boy I'm glad I left the panel saw in the truck.
718
9
Springfield Or
I love our new shop. Its so nice to work on my truck inside.
In another thread the mention of rived wheels came up. Seems I have quite a few.
Just about time to replace some rear tires
Pulled, cleaned and adjusted my injectors. Also adjusted my valves.
I built a pop tester out of a Porta Power pump, pressure gauge and one injector line.
2 Kings 2 12 And Elisha saw it, and he cried out, “My father, my father, the chariot of Israel and its horsemen!” So he saw him no more. And he took hold of his own clothes and tore them into two pieces. 13 He also took up the mantle of Elijah that had fallen from him, and went back and stood by the bank of the Jordan.14 Then he took the mantle of Elijah that had fallen from him, and struck the water, and said, “Where is the Lord God of Elijah?” And when he also had struck the water, it was divided this way and that; and Elisha crossed over.
srodocker
68
Lacey, Washington
Glad to see you posting again! nice shop! I just got one myself yet my truck is still broken at brads hopefully fixed soon!!! You coming to the rally this year?
718
9
Springfield Or
Getting ready for our annual camping trip. Haven't tested battery's in while. The battery for my Twelve Volt system was low so I charged and tested it.
It failed so it got replaced.
Now to test the charging system. I have found that I need to run Twenty eight volts or my battery's wont stay topped off. Its nice that we can adjust our voltage regulators so easily.
I use a 50 amp Vanner battery equalizer to charge the Twelve Volt system battery. This battery only runs the twelve volt stuff in the cab. The coach has its own Twelve Volt system consisting of three deep cycle battery's. They only charge with solar, shore power or the generator.
241852d1303442924-inexpensive-camper-utiliy-box-m35a2-img_20110420_145024.jpg241344d1303185294-inexpensive-camper-utiliy-box-m35a2-battery-equalizer-deepcycle-camper.jpg
Revelation 5:12 In a loud voice they sang: "Worthy is the Lamb, who was slain, to receive power and wealth and wisdom and strength and honor and glory and praise!"
718
9
Springfield Or
Because of the height of the truck my water hookup and gravity fill ended up One hundred and twelve feet off the ground.
So I plumbed another in a little lower so I don't have to stand on my tippy toes to hook up the hose.
9Do not lie to one another, seeing that you have put off the old self with its practices 10and have put on the new self, which is being renewed in knowledge after the image of its creator.
718
9
Springfield Or
I wired the old convoy light switch in so it powers the 12 volt stuff with the master switch off.
And then I carpeted the back with some leftover carpet squares we had.
20150725_102144.jpg20150725_120217.jpg20150725_121951.jpg 20150725_122025.jpg20150725_122342.jpg20150725_130237.jpg
20150725_122652.jpg20150725_131014.jpg20150725_132036.jpg20150725_132944.jpg20150725_135358.jpg20150725_133738.jpg
14It was also about these that Enoch, the seventh from Adam, prophesied, saying, “Behold, the Lord comes with ten thousands of his holy ones, 15to execute judgment on all and to convict all the ungodly of all their deeds of ungodliness that they have committed in such an ungodly way, and of all the harsh things that ungodly sinners have spoken against him.” 16These are grumblers, malcontents, following their own sinful desires; they are loud-mouthed boasters, showing favoritism to gain advantage.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
HOLY CRAP! You have an elevator to reach that?!!!!
J/K, I figured you meant 112inches...
OH, and your alt should put out 28.8 to charge the batts.
718
9
Springfield Or
For the last few months I have had what I thought was an injector knock that would come and go. Also had excessive blue smoke at idle along with heavy smoke under load.
I pulled and tested all the injectors and they tested good. So off come the heads. My son gave a helping hand.
20150818_125317.jpg20150818_145511.jpg20150826_165116.jpg20150818_131148.jpg20150916_125323.jpg20150916_125338.jpg
My home made tool.
9
Springfield Or
I found that the radius in the piston bowls were full of a soft white carbon type substance.
The Injector hole on cylinder one was almost entirely plugged with this stuff. The fuel could not spray into the cylinder but would have just dripped in.
Its is not in the pictures but the top of number one piston had a build up on it and the head had the same. My knock was the piston making contact with the head. It easily came off with a razer blade
I cleaned all the stuff off the pistons and heads and back together it went.
Truck runs perfect now, No excessive smoke at idle, lots more power and no knock.
rustystud
2,492
Woodinville, Washington
View attachment 591548View attachment 591549View attachment 591547
View attachment 591545View attachment 591546
You need to get that puppy good and hot ! That will keep that goo from forming. Plus stop using that cheap low sulpher fuel if you can.
OldDuke6
Tahlequah, Ok.
Agreed.
Run a bottle of SEAFOAM through on a tank sometime in the near future. it'll clean all that junk out, of the tank, lines, and filters. Also give a thought to adding a slight amount of ATF to your oil. With it's detergent qualities, it will help keep the oil from foaming, and keep the lubricating system clean.
I do this to my 1999 7.3L F350, and it runs better than new at 254,000 miles.
718
9
Springfield Or
Today I made an important addition to the army truck.
I also sorted the tools and parts still inside.
And I installed an antique 110 volt light fixture.
Last but not least I carpeted under the table
(Ps 12:6 [KJV])
The words of the LORD are pure words: as silver tried in a furnace of earth, purified seven times.
