Isringhausen seats
DUG
Senior Chief/Moderator
73
Mesquite, NV
I picked up a couple Isringhausen seats from a fellow SSer in San Diego today. Has anyone ever installed them in a deuce? If so, any tips?
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Cut the plate off a springer seat and weld it to your new seats, or make a copy plate and weld it to your new seats.
DUG
73
Mesquite, NV
Have you seen these installed? There is a plate on there now. I'll get better pics.
DUG
73
Mesquite, NV
Just looked again, there isn't a "plate" but there is a mounting system. I need to get the tape measure out in the morning. Lots of adjustable features.
armytruck63
9
Redlands, CA
A friend of mine put an air ride seat in his M818. The only problem we had was that the seat was too high and your thighs rubbed on the steering wheel at times.
Clay James
Reno/NV
I put similar air ride seats in my M109A3 and the cab is definitely a little cramped for them. It has a huge height adjustment range but a limited comfortable one. Too low and it's really awkward operating the pedals and too high and I'm pushed right into the steering wheel and I'm a thin guy. I had to install a pressure regulator or I would blow up the air bags in the seats at the deuces operating pressure. I just put it on the firewall where the air valve is. The driver side is pretty sturdy but the passenger side moves some because the floor is thin and flexes. I may figure out some way to reinforce the floor to stop this.
EDIT: I see you have spring seats after all.
DUG
73
Mesquite, NV
Should fit easily. They have a much smaller footprint than stock springers and box seats.
Height doesn't look to be a problem.
Katahdin
24
Scarborough, ME
Those look like they were meant to be installed there and yet comfortable at the same time. Nice work Dug! What were these seats originally installed in?
DUG
73
Mesquite, NV
No idea what they were out of. I got them from a local SSer who got them from GL.
DUG
73
Mesquite, NV
Test drive went very well. Easily one of the best mods I've ever done to my truck.
