Knuckle Boom Crane on M35A2C
DZelmer
Bridgman/Michigan
These are the rest of the pictures i have. If more are needed i will have to get them when its not covered in snow.20220605_233737.jpg
19,178
These are the rest of the pictures i have. If more are needed i will have to get them when its not covered in snow.View attachment 914694
Well... It isn't a Hiab 750. I would bet that it is a Hiab though... When the snow clears, maybe on the back of the boom?
There should be a plate (ID Plate) on there.
Looking at the outrigger, it seems like the parts would be interchangeable.
Heck, for that matter if you can get the old packing back into the cylinder and if the screw-on cap will re-thread onto the threads you might be "fixed". Was the oil white like that before it hit the ground? Like it was contaminated with water?
DZelmer
Bridgman/Michigan
Ya there is plenty of water with the oil i ran it through a centrifuge once but its hard to get all the water out with out draining all the cyl. When i gotnthe rig i drained over 5 gallons of water out of the oil tank before i even got oil. At some point some one chooped the filter and or suction strainer apart in the tank also...found that hack job when i cleaned all the trash out of the bottom of the tank.
Unfortunately my buddy slid it sideways some how with the downriggers down and it blew the cap in to 3 pieces.... only found 2 of them....the cap is cast aluminum...which i find odd but it is what it is. Hopefully i can find one or worst case have one machined if absolutely necessary.
Jbulach
2,090
Sunman Indiana
Any “good” hydraulic shop should be able to handle this repair without knowing what it came off of. With machining a new cap it wont be cheap though, even if the rod or tube is not bent.
