rustystud
- 2,464
- 113
- Woodinville, Washington
I think I need to explain the reason I said that the amount of fuel has nothing to do with timing. A given amount of fuel has a set amount of potential energy. So when your going down the road with "no" load you only need a small amount of fuel (energy) to keep the engine turning at a set RPM. When your going down the road under "full" load at the same RPM you need a lot more fuel (energy) to keep the engine turning. You didn't increase the timing just the amount of fuel (energy) needed to keep the engine turning at the set RPM.
Another way to put this is by an example I learned in trade school. They put a small amount of fuel in a tube and lit it off. The explosion was considerable but not near the same as when they put more fuel into the same tube and lit it off ! Now that was an explosion ! Same amount of "space" just more fuel (energy) . They just increased the amount of potential energy in that same space which translates into more "power" or "push" or "force" against the piston.
So by increasing the amount of fuel injected into the cylinder we are just increasing the "force" against the piston, allowing it to "push" harder against a heavier load.
