lds 427 headgasket questions
scooter01922
42
Newbury, MA
Hi all, been searching for a headgasket for the m35a1 and ran into a bit of a mystery while talking to white owl the other day. It seems the stock number for the headgasket on a lds 427-2 and a ldt 465 are the same. Concrete info on the rellationship between these two multifuel siblings has come to me over the years on here but its not really complete. I know they share a common block but the heads are different part numbers and internals are largely different. Is it really just a matter of stroke seperating these engines?? Has to be the same bore to have the same HG right?? Not going to count on the books on this one just yet, seems far too easy that these match up. On a second note, is m35tom still selling those new headgaskets? Took a look around ebay and did not see them. Help greatly appreciated :-D
dmetalmiki
2,026
London England
Same
I have replacement gaskets for my 427 and 465s. ALL SAME. 'cept the 427s are one piece. Later and 465, Seperate ring (top of cylinders) "inserts"
gringeltaube
Staff Member
2,313
Montevideo/Uruguay
........... Has to be the same bore to have the same HG right?? Not going to count on the books on this one just yet, seems far too easy that these match up. On a second note, is m35tom still selling those new headgaskets? Took a look around ebay and did not see them. Help greatly appreciated :-D
No, the stroke is the same for all MF engines; but bore is different: 4-9/16" vs. 4-5/16".
I have used the "older, separate fire ring style" - 465 gasket sets for the 427 as well. No problems at all. But I know that if I had them custom-made, 1piece, they would have to perfectly match the smaller opening.
Not sure if Tom is still selling his, at least I didn't see them advertised now, after a quick search... He sure will comment on this.
G.
edit: just found his ad, still in the old classifieds... http://www.steelsoldiers.com/vbclassified.php?do=ad&id=3718
JasonS
126
Eastern SD
Take a look at page 49 of "Troubleshooting Manual LDS-465 1 Multifuel Manual" which talks about head gaskets for the LDS-427-2.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Scoot, I have both style gaskets if you can't find what you want. I also have an LDT taken apart. If you have your heads off, I can get some measurements for you, if you want.
gringeltaube
Staff Member
2,313
Montevideo/Uruguay
Interesting! I take it from there that head gaskets have always been "one size fits all", regardless of style (1pc or multipiece w/ firerings).
G.
