Looking for Hood Hardware
Mogman
8,535
Papalote, TX
Looking for these parts on the video.
Here you go..
This is in TM 9-2320-280-24P-1
EDIT, it is easier to copy and paste the part numbers to say Google directly from the PDF than to use these pictures, there is a link to the TM, PDFs in a sticky on this forum.
You can also post your wants in the classifieds.
Mogman
8,535
Papalote, TX
I was looking at a hood today and there is nothing bolted to the holes you point out, the front and top grills are simply bolted in with bolts, washers and nuts, no "hardware" other than that but for the seal, numbers 16 and 17
Chad Lares
39
San Tan Valley, AZ
Yea, was wondering what hardware people used for these. Was looking for a "Hey, go to this website and buy these, here's the link." Nothing yet.
Mogman
8,535
Papalote, TX
All the information you need is posted, as I said there is no hardware but for bolts, nuts and washers except for the seal at the back of the top grill and all the part numbers are listed so you can search for them, I doubt anyone is selling the nuts, bolts and washers as a "kit"
The bolt size and quantity is also listed, but you can search for the actual part numbers if you want all "original" hardware.
DREDnot
434
Phoenix, AZ
Despite what the parts manual lists, Mine was all 1/4-20 with washers and lock nuts.
The large side holes on mine are capped with red plugs and not used to attach the grille. I think they get used to attach hood reinforcing panels they retrofitted on some units.
The large holes for the front grille top and rear rubber seal are most likely rubber expansion nuts in 1/4-20
