Jeepsinker
- 338
- 83
- Dry Creek, Louisiana
My intermediate axle has lost the pinion preload and given me a vibration. I've done about 800-900 miles in the past five days and the bearings have not burned up on me and it hasn't gotten any worse so I'm fairly sure the bearings are not bad, just lost the preload. I understand that this is fairly common for these axles.
My question is, how do I tell which pinion nut I need to tighten up, front or rear? I do not want to pull the gear pattern out of alignment and eat up the gears. I guess I need to remove either the side cover or top cover and just look and see which way it needs to go?
