loud power steering noise only when hot!!!!
3000gt
hernando ms
Bleed system 3 times, followed tech manual. Checked power steering level and all that jazz. No noise is heard until the truck reaches normal operating temperature. its a loud noise and seems to get worse the longer i drive it
I have no air bubbles on power steering dipstick
Could the oil be getting too thin?
I am using power steering fluid should i switch to Dextron III?
2nd question do yall remove the run flats cause the vibration from when i drive (on hard surfaces) is killing me
