Low air alarm
Jbulach
2,056
Sunman Indiana
Failsafe alarm notorious for “failing”, if your low air pressure and parking brake warning lights are still functioning correctly put a piece of tape over the speaker until you decide if you want to spend the money to replace.
CHIEFSONN
Break light and alarm is what I'm concerned with, that is my alarm.I drove it a little alarm. My street and it had breaks but I wasn't about to take any further
simp5782
Feo, Fuerte y Formal
9,264
Mason, TN
If you have air pressure you have brakes.
If you parking brake handle is down then the parking brake is off.
Ajax MD
1,420
Mayo, MD
What does the air pressure gauge say? If it is within the normal range, the brakes are safe. The alarm is to call your attention to the gauge in case you're not looking, when a failure occurs. Sounds like a simple buzzer failure.
CHIEFSONN
Thank you for your reply, the air pressure was up there,as of now l am down with a cold and perfer to stay in side.
Both the brake light and alarm would not stop,I was going to allow my son to take it to work with all this snow we were hit with but I wasn't going to take it with the above mentioned.
When l do go out in the next few days l will answer your air pressure question.
Thanks wayne
CHIEFSONN
Thanks wayne
