Skinny
- 486
- 83
- Portsmouth, NH
Or spend a $100 on a clamp on reluctor wheel to do it right.
Sent from my SM-T380 using Tapatalk
Everyone I know wired their 4-low signal wire to a dash toggle
Sent from my SM-G970U using Tapatalk
Long time since I've updated this thread. Got a fair amount done on the truck but it's still.not driving. I switched to a 4L80E transmission because I got a good deal on a used core to rebuild. After getting mine done and all the parts to mate an NP205 to it, I would go the 2wd 4L80 route. I had to install a tone ring on the rear planetary housing, and the adaptor for the 4wd transmission is getting harder to find since it's a bit more of a hassle to build for this application. 2wd transmissions have all the proper VSS stuff already.
My FItech harness is all installed. I will be sending my t case out soon to be machined for the oversized bearing needed for the input shift (sending to ORD).
I installed ORD 4" Rear shackle flip, front HD springs, Bilstein shocks, and full crossover steering and a 2wd steering box. Steering box brace, Rear mounted 31gal blazer tank and OEM cross members I got from a suburban I parted out. Full Killmat in the cab floor. American Autowire full chassis wiring kit I will be installing very soon. I got some 37" BFG HMMWV tires and dual beadlocks. I cut and installed new Trailworthy Fab stamped centers, to get the offset correct for the truck without adaptors. Also installed their light weight PVC beadlock rings inside to get rid of the big heavy run flat stuff. Tilt steering column. S250 radio box for storage but will eventually make a camper out of it. Built a custom rear bumper out of a civilian bumper and a bent CUCV bumper I got a good deal on.
Lots of other little stuff waiting to go on and I should have time to get back at it soon. Will update with more pics.
