Lssv cucv
Stonepicker1
77
Coconut Creek, Florida
FYI:
Battery voltage with the engine off for the 12 V passenger side battery is 12.74 V. With it running it’s 14.58 V.
Battery voltage with the engine off for the 24 V battery on the driver side is 24.80 V. with it running it’s 29.35 V.
Alternator voltage with the engine off driver side alternator is 12.64 V. With it running it’s 14.62 V.
Alternator voltage with the engine off on the passenger side 24 V alternator is 12.20 V. With it running it is 29.31 V.
Stonepicker1
77
The alternator that is putting out 24 V has the marking stamped on the case for a 12V. The alternator has a part number stamped on the case showing 12 V, also 105 A.
I will probably open up the back of the alternator to see what 24 V regulator is there so I can order a spare.
87cr250r
1,942
Rodeo, Ca
I converted my M1008 to serpentine belt. I couldn't find a CS130 alternator in isolated ground so I drilled out the mounting holes and installed plastic sleeves and Garolite washers. Those look like CS130 alternators in the LSSV.
dstang97
30
Clover, SC
Did you have 2 alternators? Like a regular cucv?
87cr250r
1,942
Rodeo, Ca
I have a regular CUCV, 1986. I bought an eBay 6.5 from a 2001 C3500 truck because it had most of the brackets to support dual alternators and AC. I still have dual alternators now. There is a company that makes pigtails to plug the 27SI connectors into the CS130 so everything else was plug and play once I isolated the passenger side alternator body.1000001552.png
