M135 Wiper parts needed?
Brad
10
Bolivar, Pa
We need two of the small collar like parts that are held on the wiper motor shaft by the two small Allen set screws. Ours are worn nearly smooth. We would replace if we can find new or much better ones? Anyone know where these may be found? Thanks
Brad
10
Bolivar, Pa
Thanks NDT. In your photo the part(s) I need are not seen. They are what the actual wiper arm goes slided over. It is a grooved part that looks to be made of non ferris metal, maybe aluminum or pot metal. It has two small set Allen screw to tighten it to the actual motor shaft that goes to the outside of the cab.
I can make ours work but I would prefer new ones.
Thanks again.
JGBallew
Paducah, Kentucky
ANCO used to be the people who made the wiper shaft adapters, the couple I have on hand are the 47-16, which is for a shaft with flats on opposite sides. a brief search shows the ANCO 42-09, which seems similar to what you're after.
You might try swap meets or rod shows, as sadly the ANCO stuff seems to be mostly out of production.
