M35A2 Air Compressor Bottom Seal
Dasgog
148
Tucson, AZ
Hello
I was reading in the TM that the radiator had to be removed in order to get the AC out... Is it possible to just remove the grill and loosen top bolt on both bottom bolts and angle it back?
My bottom seal is leaking and didn’t wanna do it just yet if whole Radiator needed to get taken out.
I tried but when the outer flange for the AC belt was being unscrewed it tapped out against the radiator so I know I need to either remove it or angle it.
thanks
cattlerepairman
3,129
NORTH (Canada)
Has been a while but I think I just angled it. In a w/w truck the rad has less room to tilt forward than in a wo/w. I don't remember details so it probably worked.
Sent from my SM-G950W using Tapatalk
