M35A2 Winch Operations
deuce808
Alpharetta Ga
5 ton winch
will the winch off the 5ton fit on a deuce.. or are the frame rail too close on the deuce to fit the 5 ton winch....
and what is the manufacturer of the deuce winch or is there just one...
what about rear mounting a winch on the deuce
is there any website to visit where it shouw the variations of the 6x6.. i heard you can mount a PTO driven winch in the M36.... at any rate i want a power source for my M36
Keith_J
1,314
Schertz TX
I think the cable (wire rope) is actually 6x19 improved plow steel fiber core, 7/16" I have never heard of 6x9 wire rope designation.
In IPS, it is about 18k rated breaking strength. With the wedge socket, it should be at least 15k breaking strength. Using 2-part line recovery, it will easily haul an unloaded deuce from axle depth mud in neutral. Voice of experience here ;-)
TehTDK
41
Denmark
Any chance of a higher quality scan of those pages. They are rather hard to read on a larger screen.
hndrsonj
Senior Chief/Moderator
358
Cheyenne, WY
They come through fine on my screen. The manual should also be in the technical manual section on SS.
TehTDK
41
Denmark
hndrsonj, do you have the number for it?. And I mean I can read it, but I have to zoom on the image and it then quickly gets rather grainy...
Brenda
Wilmington Ca
That would be mine.... It's been posted here in another thread, but good to have here.
http://www.youtube.com/watch?v=VxnFB_Lz-ss
Thanks for this! I've always done it with 2 people (one on outside to lock drum) but now I can see how to do it alone. I've always made sure there is no one anywhere near pull area as I know it might never happen but I've got a fear of cable snap or slap hurting someone.
frank8003
4,978
Ft. Lauderdale, Florida
The Garwood "self recovery" winch on M35A2 is not for, or was not meant to be, for pulling stumps.
So I say the big secret and be quite then after, ..............yeah, maybe.
Winch operation is a two or more soldier job, and would be good to lock the hood open.
The thing is high maintenance, better if used then forgotten.
With winch cable played out ahead to fixed fortification one clears the area, puts truck in Transfer low and Transmission in low forward and engage Winch and truck gearbox at same time. With proper operation one doesn't need a tank, tracked thing to get unstuck. Climb mountains and such a cable reel at a time, well, 100 feet or so. It is meant to help, not be the sole source of pulling.
Most all of them are broke or rotted.
