M54 starting problem
Bangman
Just received two (2) M54 MFs in the last three months. One started beautifully until some homeless P.O.S. got in and turned on the Battery Switch and ran down the batteries to "0". After that episode, I recharged both batteries up and cleaned all my cables and attempted to start. Now I don't have the low air pressure annunciator sounding any more not can I start the truck. Turning on the Ignition Battery Switch the Amp/Volt Meter moves to the green and the Fuel Gauge registers but I have now low air pressure annunciator sound nor can I start the truck. Ignition Switch was removed and that tested ok on closure. Is there a circuit breaker somewhere or a low voltage interupt circuit? Ass ist woul be greatly appreciated!!
Thanks,
Bill
steelsoldiers
3,959
Charleston, WV
Coincidence maybe? Try taking the low air buzzer out and hooking it up to straight voltage and see if it works. If it does, then you know it is in your wiring. There is one circuit breaker on the firewall near the steering column. I don't have a wiring schematic in front of me right now to tell you what's on it though.
Desert Rat
Bill,
You might wish to include your town or state in your signature. I need to look at your profile in order to know where you are and possibly guide you to some local help. Having the info in your signature would expediate the process.
Bangman
Originally posted by Desert Rat
Bill,
I'm new to this so I'll have to update that info in the Profile area. But for now, it's Bill Curtin, Novato, Ca. (Just above San Fran.)
Two M54s, one M62
