M54A2 bleeder screw size?
firefox
General
51
Berkeley CA
Here is the entry from the TM:
2530-274-4510 SCREW,MACHINE: BLEEDER A EA 1 * * * * 107 4
7409322(19207)
I want to put speed bleeders on my truck.
Thanks for any help!
porkysplace
1,486
mid- michigan
steel,spec data,fed,no. Qq-s-633,fs 1018 to fs 1025 or fsb1112 or fsb 1113; zinc-plated finish; dim. Data,1-17/64 in. Lg over-all,7/16 in. Across hex flats,1/8 in. Lg hex,7/8 in. From valve end to nearest hex shoulder; barbed type hose connector,barbed type data,9/64 in. From hex shoulder to nearest edge of barbed hose connector,0.308 in. Largest dia of hose connector,0.187 in. Smallest dia of hose connector,17/64 in. Lg hose connector; valve seat end data,0.339 in. Largest od of taper,1/8 in. Lg taper,9/32 in. Lg excluding threaded portion,7/32 in. From center of inlet hole to valve end,3/32 in. Dia inlet hole,external thd data,7/16 - 20,unf,rh,class 2a thd,0.509 in. Lg; drain hole data,0.116 in. Dia,11/32 in. Lg,1/8 in. Dia,3/4 in. Lg
firefox
General
51
Berkeley CA
I must be missing something. This doesn't seem like the specs to a bleed screw, but maybe
I am just ignorant.
I also need the data for the bleed screws on the air pack which is listed as such:
PAOZZ 2530-294-6747 SCREW,BLEEDER: BODY ASSEMBLY EA 2 * * * * 108 2
AND CYLINDER CAP
7376729(19207)
I suspect that they are a different size from the wheel cylinders.
Thanks!
porkysplace
1,486
mid- michigan
Yeah it's hard to figure out , but says bleeder screw
If you sort trough it all this, the thread size is
7/16 - 20,unf
0.509 in. Long , so basicly 1/2 inch of threads
1,124
7/16 - 20,unf
The bleeder screw is 7/16"?
You know the studs, nuts and bolts on the top of the M44 series knuckle (that hold the steering arm to the knuckle) are 9/16"?
firefox
General
51
Berkeley CA
Thanks guys! What about the size for the air pack? Are they the same? I am thinking not since the TM shows a different part number as I listed in my second post.
Thanks again for your help!
porkysplace
1,486
mid- michigan
That's what came up in searching , it should be easy enough to with a caliper.
firefox
General
51
Berkeley CA
My problem is I need to order the new parts and my truck is in the next town over in storage.
Thanks again guys, I really appreciate your support.
I now understand what porkysplace first replied after rereading it a few times. Thanks!
