M756A2 pipeline construction vehicle
Beyond Biodiesel
37
Prescott, AZ
Well, give Jack a try on the shipping costs, because he seemed to think that he could ship the whole bed reasonably. Maybe you could recoup some of your expenses selling your bed and partial stiff-legs to someone else.
AMGeneral
114
Connelly Springs, NC
I'm not trying to hijack anyones thread here,but I am assuming a relatively complete non turbo pipeline deuce would be worth more than a standard multifuel deuce in the same condition?
I ask because I found one locally I am thinking about buying.
Beyond Biodiesel
37
Prescott, AZ
There is so little known about pipeline trucks, I am happy for anyone to post on the topic on this thread.
So, AMGeneral, how much are they asking for the pipeline truck that you saw, and what does it have with it? The rigging is the big deal, and few surplus pipeline trucks have the complete kit. All mine had was the stiff-legs, and they were missing the T pins, and on leg was missing its hair pin.
1,814
Brandon, it's certainly a more capable truck. If it's not complete, the task of completing it can be daunting. Gotta be one of my favorites. Would bet lunch the one you found is a 1969.
AMGeneral
114
You would be correct Kenny.
Below are the pics of said truck.
1,814
Missing gin poles and at least the headache rack. Maybe even the winch. Not much left.
Beyond Biodiesel
37
Prescott, AZ
It is usually a long search, especially for the trunion.
Recovry4x4, or anyone else. Has anyone made careful measurements of the pipeline truck rigging? I am planning on purchasing, and/or fabricating the complete rigging kit for my pipeline truck so that I can put it to work soon.
Also, does anyone have a link to a TM that covers towing, and rigging for pipeline trucks, and other trucks?
Evil Dr. Porkchop
269
Colchester, VT
https://www.steelsoldiers.com/showthread.php?149292-The-VTCS-m756a2-Pipeline-Truck&highlight=
We’ve been trying to get a drawing or scan of the trunnion done but at the same time don’t want to ship it anywhere since it’s irreplaceable.
Some info on the rigging is in the back of the operator’s book, the earlier version is a little more in depth. It’s a very useful truck when the gin poles and winch are working.
Evil Dr. Porkchop
269
Colchester, VT
There are 4 blocks in the BII for the pipeline truck (in addition to the standard block used on all front winch equipped trucks). From left to right you've got the block with welded hooks for the rear anchor, the block without hooks for the center anchor, the block with the trunnion, a block with a hook pinned on, and the front winch block.
You've already got the anchors so that's a good start. The book lists a different part number for each block because the anchor/ trunnion went with the block when you ordered them. They're all the same except for the one with the welded hooks and those are easy to weld on.
The NSN for the block with the pinned on hook is 3940-00-151-6769. The military still has these blocks kicking around and they were on ebay for a while for around $200 each. When we were putting together the rigging for our truck we won a lot of 8 blocks from GL for a bit less per block. The attachments just pin on so remove the hooks from 3 and keep one with the hook.
After that you'll need to cut out a couple pieces of 1/4" steel in the correct shape and weld them to the sides of the block for the rear anchor. Very easy to do. The block in red primer is my homemade rear anchor block next to a friend of mine's original block.
For boom chains we're using 3/4" pear links to go around the trunnion. Not an exact match but finding original boom chains will be next to impossible. The chains are 1/2" and just under 24 feet long if I remember right. Get a 50 foot length and cut it down. We're connecting the pear links with some small shackles and then the other end of the chain needs a grab hook.
If you've got any questions about individual pieces or anything in the BII list just let me know. I think I've got it mostly figured out at this point.
Evil Dr. Porkchop
269
Colchester, VT
I will do that when I get a chance to fold the gin poles in. It probably wouldn’t be too difficult to build something that will work alright even if it looks a little different.
Beyond Biodiesel
37
Prescott, AZ
Another option is just knowing the length of the trunnion, and the diameter of one of the snatch blocks would be very useful. It looks like the trunnion is about 12" long, and the snatch blocks look like they might be 8" in diameter.
Desert Deuce
17
Chino Valley, AZ
I still have my M756A2. Still in the same condition as in the pictures from 2009. Found original boom chains on ebay about 6 years ago. I too will not ship my trunnion anywhere. I've reduced my collection to the following:
1967 M756A2
1970 M35A2 w/w
1965 M35A2
1965 M109A3
1985 M49A2c
1968 M54A1c
1969 XM818 w/w
1967 M128A2c
1952 M345
1954 M107
1967 ENG3
1972 M105A2
1967 M127
1992 M101A3
Will eventually get down to a couple trucks and trailers. Haven't decided which ones yet. I still log in and read posts, this is my first post in a few years. Still enjoy this site and reading all the new members posts!
Kevin
Evil Dr. Porkchop
269
Colchester, VT
I'd definitely keep an eye out for the original blocks. I'm still going to get the trunnion info next time I have the poles down, I've been using them quite a bit lately.
Any chance you could post some pictures of the original boom chains sometime? I'd be interested in seeing the pear links. How do you know they're original, were they NOS or is there a number tag on them? I've seen pics of the set from when they tested the pipeline bed and they had longer pear links than I'm using, curious if the later sets are the same.
Desert Deuce
17
Chino Valley, AZ
It's been a few years since I bought them, I did verify they were correct, it was the correct NSN, they are unique to the M756A2. Yes, they were NOS with tags. The seller had several sets, I let Chris know and he bought a set for his dad's M756A2. This was before you had your truck (I believe). They are packed in a trailer right now, but i would glad to help you out with pictures.
On another note, I'm still interested in have you fab some hooks for me. Love your M756A2, you've done a great job!
Evil Dr. Porkchop
269
Colchester, VT
Thanks, I'll have to keep an eye out for a set. I'd still be happy to make some rear anchor block hooks for you. I can either make a template to line them up on the block or tack or weld them to a block if you want to ship the sides to me.
Beyond Biodiesel, if you want a set of the 1/4" plate hooks that need to be welded to the rear anchor block I'd be happy to make a set for you too.
Luckily a friend of mine had an original rear anchor block that I borrowed and copied. Might be the same exact one Kenny pictured on page 1.
The nice thing is all the BII is out there, we just need to figure out getting some of the hard to find stuff reproduced so all the trucks can have a complete set. I've got a single stake pocket adapter too, but getting the trunnion done is the main thing needed right now. Chris has been looking for a long time!
