M880 5.2 smoke coming out of air breather inlet
Shug
Berrien springs michigan
Hey guys. So the 318’s in our trucks have a plastic tooth timing gear in them. If you are having trouble with a little smoke coming back out the carb and low power. This is not the most favorable place to start but... they do wear and can jump out of time one or two teeth. They will still run but low on power on can let some smoke back out the carb as the valves are no longer closed at the proper degree. Hopefully This is not your problem. But it’s definitely something to think about if you can’t find any other probable cause.
Tracer
13,659
Hawthorne, NV.
dodjh. This happened to my neighbors 318 in his Dodge Dart. It started running poor, and he suspected the timing chain gave way, so when he drained the oil plastic debris from the timing sprockets came out. You might give an oil change a try and see if you don't find some timing chain and sprocket debris in the oil.
