M915A1 Tractor/Truck Air Question - Add Fitting for Pressurizing System Before Start
swbradley1
Modertator
1,573
Dayton, OH
Now I thought it would be easy to find an answer using the Internet but I was mistaken.
It's simple, where is the best place to add a quick disconnect hose fitting (with valve) to the air system that I can use to pressurize the truck before start?
I do not want to screw it up or introduce an issue into the braking system.
I can use gladhands AFTER it is running for air.
Reason: I try to keep the truck inside and it bleeds down eventually and if I start the truck inside to air it up eventually the CO will be too much. Even as big as my barn is and with two 20 foot doors open it is a little much in there.
thanks in advance
19,174
thanks in advance
Well... If you charge the air system with the front gladhand connection, you won't need any "extra parts". The only thing to consider is that your air compressor might introduce water into the air system...
chucky
18,748
TN .
Why not just put a air line quick connect in a air tank like you would hook up a airline from your shop hose to air up a tire ! use the female brass quick con in the tank and then put 2 male ends on a short hose to hook shop or other truck can air up the empty truck and now you have a hook up to run a air impact from your truck in the future !
swbradley1
Modertator
1,573
Dayton, OH
The only thing I found remotely resembling what I want said to connect at air dryer and not use a tank. I do have plugs that could be removed in the tank but screwing with the dryer makes me nervous.
Now go back to drinking your bourbon and smoking fancy cigars. Next answer.
chucky
18,748
TN .
Im just doin it for you ! Im saving your lungs liver and wallet ! Use the air tank plug hole and have a useful quick connect !
Guyfang
22,378
Burgkunstadt, Germany
This is the way we always did it, and never had a problem. The Germans at the POMCOS site, (Prepositioned Equipment Sites) had a small compressor mounted on a tiny trailer, and a step and fetch it to pull it along. He could do a climate controlled building full of several hundred vehicles in a day.
swbradley1
Modertator
1,573
Dayton, OH
I'll add that to the list of things to work on/fix, new vlalves and gladhands on the front to air it up that way.
I already have the gladhand hoses setup for airing tires with inflator and truck to truck hoses as well.
Thanks to everyone. I'm sure there will be more posts for this truck than I every posted for the Deuces or 813.
Jbulach
2,090
Sunman Indiana
My M915A1 has a quick connect air fitting on the tank behind the driver side step that goes up to the walking plate. I put together two male air fittings so I can connect two air hoses to supply air to the truck.
Is that the wet tank?
swbradley1
Modertator
1,573
Dayton, OH
Ray, Could you send me a pic of it? I see everything in the manual but not sure where you put it.
thx
chucky
18,748
TN .
We like pictures ! post more pics for us to sit around armchair quarterback what you need to do next ! You need more guidance !
