m920 broken axle
R Racing
15
St. Leonard, MD
Ok here is my delemia, I apparently broke a axle on my m920 driving it up the driveway last weds( driveway is 18% grade with 180 degree wrap) I had aproched in to high a gear and got the truck in a hop. I didn't relize it til today when I needed to move it that the drivers rear wheel was free wheeling and not driving. I removed the paint off of the axle tag info to see if I could get a axle locally and or quickly . But it has been sand blasted to the point that this is all I can make out. There looks like there could have been more info on the tag. But it looks worn off.
A 3121 N 378
137/80
Rockwell international
Can anyone shead some light as if this seems to be correct or if you can contibute any info to help me find a replacement Axle would be greatly appriciated.
Bighurt
46
Minot, ND
Jim the TM will have a part number.
Told you months ago you should have just let me have it, now look you're in a pickle...LOL
Trango
22
Boulder, CO
I wonder if the axle shafts for other, earlier 800-series 5 tons would fit. Any chance you have a length and spline count? If you are worried about gear oil spilling out, you could jack or drive that one tire up on a block, hopefully raising the bottom of the spindle above the fill hole on the pumpkin.
M1075
Oklahoma City
M920 is much too different from a M839 series 5 ton. Maybe you are thinking OP has the M939 series instead?
Castle Bravo
Hundredaire Socialite
219
Arizona
A 3121 N 378
137/80
This is what I got for the driver's side rear rear axle shaft -
3202-Z-7384
Each axle shaft in the truck has a different part number, apparently.
There even appears to be one on ebay right now...
The M920 20 ton has much larger axle shafts than the M809 5 ton.
R Racing
15
St. Leonard, MD
Unfortunately the TM gives a general # and does not give the axle info ( Spline , Dia, Length according to the local rockwell dealer) So I'm back to square 1. The numbers I gave them off of the axle that he asked for came up obsolete.
R Racing
15
St. Leonard, MD
3202-Z-7384
Thank you ! Thank you ! Thank you !! You are a life saver !!!! :beer:
R Racing
15
St. Leonard, MD
Jim,
I forgot to update you on the fuel shut off.
Got it installed and with the help of AMGeneral it is now working flawlessly.
Thanks again for the assist.
I owe ya one.
I'm so glad that worked out for you Richard !!:beer: I couldnt imagine climbing up under the hood everytime I would have to turn my truck off and on . :gimp2:
I was able to order that Axle off of e bay and hopefully will be back up and running soon ! I also broke a spring strap . but thats a easy fix. hopefully nothing else was harmed. When it happened I was a bit to hard on the throttle as to keep me from rolling back down the hill. The sad part was I knew better, but the truck was at cat so long I was giddy . and with the trans working flawlessly I was feeling my oats and left it in 7th instead of 4th like I normally use. I told several people I had swore the axle broke . But couldn't prove it until today when it was a limp noodle.
Thanks for everyones help !
Jim
Castle Bravo
219
Arizona
Double check that I read everything right. I am not actively trying to deceive you, but I may have read it wrong. That number came out of the -24P manual.
I don't want you to purchase that axle then have it be the wrong thing and blame me! :)
Bighurt
46
Minot, ND
Forward Rear Drivers side - 3202-C-7387
Rear Rear Drivers Side - 3202-Z-7384
Bighurt
46
Minot, ND
Hey Jeremy, could that be a 3202-C-7387 ? not finding the 3202-Z-7387 It could be right but I haven't found it online yet ?
yeah...that's weird I copy and pasted the numbers...
And it cross references to a MERITOR number since Rockwell makes MERITOR...LOL
Trango
22
Boulder, CO
Guilty as charged - sorry, I had just looked at 5 ton axles on eBay and was of a one track mind. Excellent deduction, by the way!
Best,
Bob
kochevnik
Colville WA
Big thx Bighurt for that manuals site - they had EVERYTHING in one place on their home page - that is a great resource - I even found M1070 manuals I have been looking for - many thx again.
Castle Bravo
219
Arizona
Maybe I'm reading it wrong, but I'm taking "LH" to be drivers side and "RH" to be passenger side.
Here is what the -24P says.
Forward Rear Axle -
12 PAOZZ 78500 3202-Z-7384 .SHAFT,AXLE,RH 1
UOC:U22,U23,U24,U25,U26
18 PAOZZ 78500 3202-C-7387 .SHAFT,AXLE,LH 1
Rear Rear Axle -
10 PAOZZ 78500 3202-C-7387 .SHAFT,AXLE,AUTOMOTI RH 1
17 PAOZZ 78500 3202-Z-7384 .SHAFT,AXLE,AUTOMOTI 1
I take that to mean this -
Forward Rear Axle Passenger Side 3202-Z-7384
Forward Rear Axle Driver Side 3202-C-7387
Rear Rear Axle Passenger Side 3202-C-7387
Rear Rear Axle Driver Side 3202-Z-7384
I'm not clear on which one you broke - I assumed "driver's rear wheel" meant the rear rear axle. I've always called them front, middle, and rear, not front, forward rear, and rear rear as the TM does.
I hope I haven't steered you wrong. :mad:
R Racing
15
St. Leonard, MD
Yes its the drivers side rear rear, lol I just want to get it fixed but yes its the rear rear on the drivers side. hopefully the mystery will be solved soon .
