- 4,727
- 1,096
- 113
- Gaithersburg, MD
I would bet that most trucks with ISO beds have lockers.
Rest in Peace Cdub. Gone too soon.
Yes, Detroit lockers. I have never heard of a USMC truck with lockers in the front axle. They may have existed, but not in the M809 or M939 series to my knowledge.Thanks fellas!
I forgot, also wanted to verify the Marine trucks used Detroit lockers in just the rears. No selectable or front lockers?
I was thinking to put Detroit Lockers in all three of my axles. Next to getting my winch operational, lockers are next on my list. USMC has used Detroit Lockers in the two tandem rears, but has anyone here has lockers in all three axles on a M809 series? Just looking ahead to benefits/complications with the T138 case. My rig will see road miles doing PM drives around town as well as deep snow wheeling, mud, and plenty of hard packed dirt. Many wheelers use a Detroit in the front but they have hubs that can be unlocked. I will not.Yes, Detroit lockers. I have never heard of a USMC truck with lockers in the front axle. They may have existed, but not in the M809 or M939 series to my knowledge.
It's going to bind on the turn.I was thinking to put Detroit Lockers in all three of my axles. Next to getting my winch operational, lockers are next on my list. USMC has used Detroit Lockers in the two tandem rears, but has anyone here has lockers in all three axles on a M809 series? Just looking ahead to benefits/complications with the T138 case. My rig will see road miles doing PM drives around town as well as deep snow wheeling, mud, and plenty of hard packed dirt. Many wheelers use a Detroit in the front but they have hubs that can be unlocked. I will not.
Anyone had experience with this?
Anyone with a M939A2 running 16 R20 wheels know the distance between the two wheels in the rear. Wanting to replace my 14 R20's and get a set of 16 R20's cause of how deep the snow and mud get here and also put at set of chains on at least the front rear axle and the front axle itself.
Going up 30 degree ridge to get home doesn't always happen with the 5 ton, sun doesn't shine on particular section and even with deflated tires and traction block I sometimes end up finding myself going backwards.
Go the long way and I find drifts that have melted and packed down hard higher than the axles.
3 finger width between them at the narrowest pointAnyone with a M939A2 running 16 R20 wheels know the distance between the two wheels in the rear. Wanting to replace my 14 R20's and get a set of 16 R20's cause of how deep the snow and mud get here and also put at set of chains on at least the front rear axle and the front axle itself.
With XZL 16.00r20s I have about an inch between mine on a M813 6X6 that I think is the same as the 900 series. Not enough space for chains. I plan to make a single chain that wraps both rear tires like a tank tread.Anyone with a M939A2 running 16 R20 wheels know the distance between the two wheels in the rear. Wanting to replace my 14 R20's and get a set of 16 R20's cause of how deep the snow and mud get here and also put at set of chains on at least the front rear axle and the front axle itself.
Be afraid one slips and snap the chain, plus the weight. I put duals on my semi and they are heavy with limited room due to a flatbed I have on my semi. Thanks for the visual!With XZL 16.00r20s I have about an inch between mine on a M813 6X6 that I think is the same as the 900 series. Not enoughspace for chains. I plan to make a a single chain that wraps both rear tires like a tank tread. View attachment 893431View attachment 893432
Yes there are pictures of 5 tons with tracks.
I didn't dig deep, though thanks. Just wonder if chains would act the same way. Would be heavy as hell with chains and not easily taken off just like those tracks.Yes there are pictures of 5 tons with tracks.
Just put lockers in the front rear axle only.With XZL 16.00R20s and steel HEMTT wheels with solid run flats my tires are about 615+ a tire already. The only thing I am wondering about is when I run a "tandem" chain set with Detroit lockers in both rears, will the lockers fight each other being loosely chained to one another? Or will I not even notice. Been thinking on this the last few weeks.
