M923 Upgrade to the Single tires?
MP_1
germany
Hello together,
i have a M923 with the "small 11:00 R20 tires" and i will change now to the 14:00 R20 tires from the M923A1 or A2.
Can somebody tell me what i need to modify me truck`?
Is it enough just to change the tieres with rims? Or do i need more parts?
I am a absolute greenhorn in the M 923 project:)
Thanks for help
Andy
wsucougarx
65
Washington State
I replaced my 1100's with 395's. I used FMTV wheels and just mounted them. No modification is necessary for the change. The only thing is using lugnuts in the rears rather than the thimble like nuts as you would use for the duals. You'll need to stow your spare in the bed and have some means of getting the spare in/out of the rear. You could use your existing spare tire rack but you'll need to do some mods to it for it to work (relocate intake stack, widen spare rack, etc)
goldneagle
872
Slidell, LA
If you are doing all this to get more speed out of the truck be aware that most of the super singles are only rated 55 MPH max. The Goodyear 11.00-20 G177 are rated 65 MPH max. All the 14.00-20 get you is lower RPMs at 55 MPH VS the 11.00-20s.
MP_1
germany
just for my better understanding:)
I have the 11:00 R20 tires with two tires per side per axle in the rear installed (M923)
I have a set of tires with rims from a M923A1 (14:00 R20) Single tire.
This single tires with the rims i would like to install now on my truck.
Do i not need other wheel hub or something???
Or can i just install them??
MP_1
germany
Thank you Mike for your help. Can i ask you if i have another quetsion?:)
I want to have this tires, because fo me it looks better:)
MP_1
germany
one more Mike:)
can you show me which nuts i have to change?
Because a mechanicer here told me i have to trun the wheel hub???
Thnaks
tie6044
42
Blaine, MN
You don't need to flip the hub, if you are using wheels/tires from an A1 or A2 truck then the rims can be run either way, dished in or out.
One question I have is why can't you just run the thimble style lug nuts in the rear rather than buying 40 front style ones?
RIDDLE1
Americus GA
I'm wondering the same. I still have the buds on the back from where I converted my A0 to and A1. Zero problems so far.
juanprado
2,772
Metairie/La (N'awlins)
I believe you will also need the speedo gear adapter/thingy on the a1 & a2 as the base model does not have it in order for the speedo/odometer to read correctly with the different size tire.
350TacoZilla
Hancock MD
from what other people have posted on the board if you use the thimble style lug nuts they hold the rear wheels out from the mating surface of drum and can lead to the wheels cracking from the 1/4 of flex. I think most people had this problem with hemtt wheels but its a valid point that the wheel should be drawn tight back to the WMS not resting on the thimble like your outer dual rim is made to. if you are using the 5ton combat rims that came on the A1 or A2 trucks you may not have a problem with your stock lugs being long enough and wont even need the thimbles, from what I read the hemtt wheels have a thicker mounting surface making the stock lugs too short.
EDIT: also some people turned the thimbles down so they dont have the shouldered part on them and the wheels slide straight back to the WMS like they should.
tie6044
42
Blaine, MN
You don't use the thimbles that way, I just put the rim on first and use the thimbles to hold the tire/rim on, kind of like the way it holds the inner dual on in the stock form. Don't put the thimbles on first or you won't have the rim flush to the mounting surface.
4,654
I've been running thimbles on the rear of my deuce for a while, got the right side swapped out. Have some for the left now, just haven't had time to do anything with them. Zero problems with them though.
quickfarms
24
Orange Junction, CA
M923 Upgrade to the Singel tires?
There are two issues with using the thimble nuts alone.
The first issue is they have a habit of loosening up.
The second issue is they can crack. The Flange in the thimble nut is designed to have the second rim on it and the corresponding nut.
Csm Davis
376
Hattiesburg, Mississippi
Re: M923 Upgrade to the Singel tires?
Guys don't cheap out here buy the right nuts, you will spend a thousand to get the big wheels and tires but not 100 to get the right nuts to mount them?
MP_1
germany
what are thimble nuts?
Which nuts are the right one?
I just have to know which one i need, than i willl buy a set of the srews.
To get it on one point to change the wheels, you just need other nuts!??
M35A2-AZ
377
Tonopah, AZ
The right nuts or the ones that are used for the front wheels.
The thimbles are what holds the first wheel on when you are running dual wheels.
juanprado
2,772
Yes, the bud cap/nut needs to be removed to get the inner tire off. It acts at the lug nut holding the inner dual tire.
If you are converting to a super single then use the same lug nuts as the front on the original studs. You should not have to do anything to the studs. SAme outer diameter of 1 1/2 but inner thread is different diameter.
Remember that there is right and left hand threads on this truck!
Please be safe!
