- 2,627
- 2,098
- 113
- Sunman Indiana
Thought I would post some pictures for my fix of the bent up and broken bracket inside my tower on my M925A2.You can see the previous repair of bolting the brackets back to the side after the spot welds broke loose.A picture of the inside, I straightened the brackets out best I could shortly after I bought the truck. Now it broke in two where it was bolted to the side of the tower.One more shot, the lower brackets the cables clamp to.
I drilled out the remaining spot welds and removed the lever pivot bracket for straightening and reinforcement.As straight as I could get it!
