M939 and M915A1 PTO info
simp5782
Feo, Fuerte y Formal
9,317
Mason, TN
Will bump this.
The pto for the HEMTT trucks is part number 308813 according to the TM. It is an air shift with a 7/8" - 13spline coupler.
HEMTTs use a HT740D transmission. That is the same type of transmission of the HT754CR. These are found pretty cheap on ebay.
simp5782
9,317
Mason, TN
Muncie PTO # TG6SU6004A3KX is a 54hp Air shift with a 7/8" 13SPLINE output for a direct pump bolt on.
This PTO will fit both the HT700 series in the HET, HEMTT, M915,M916s and the MT600 series in the 939s. They use a 60 series gear that will work on both transmission.
These are not pressure lubed PTOs as apparently the torque converter slings up plenty of fluid to coat the gears.
PTO costs around $882. Can be built in a day from muncie. In order to save money, order the PTO from a muncie distributor in another state than your own. Then have them drop ship it to you. This way you save on not paying the taxes on it and that can go towards shipping cost.
I did not like the clutch style shift of the Chelsea units.
You can not use this pump with a 53 series cross pump. The pump is too long and hits the transmission.
Lukes_deuce
123
Long Island, NY
Excellent info as usual Simp! Thank you
