- 7,475
- 19,283
- 113
- Charlotte NC
.Just a tip... you should consider closing off the ~ 1/2" opening where the wires would normally feed into the load terminals on the AC Reconnection box. I had one of my boxes taken out by mice and it was up on its trailer like yours. Mice love to nest in the bottom of that box in winter!
Several ways to close off mouse access to box internals:
1. Screen off the interior opening located in rear of load terminals that leads down to the transformer area with hardware cloth.
2. If no need to retain access to the load terminals you could screw or glue a solid flap (metal, wood, or?) across the external wire entry opening slot on external hinged flap.
Steel Wool stuffed onto openings will help with that problem as well. Apparently the little "so and so's" don't like to chew on the wire. That stuff is relatively cheap at a hardware store too...
