- 16,066
- 22,647
- 113
- Burgkunstadt, Germany
From the first picture you posted, it looked like the lever was locked down with wire. So I assumed it was. My bad.
Yes, that is one big difference between the models. On the MEP-015A, the outside lever is used to connect the electric actuator up to, and the back lever would be wired down. In your case, the MEP-006A is a NON PRECISE model, and the lever positions are reversed. Front wired forward, and the throttle cable hooked to the back lever.
