MEP-016, MEP-017 Bellhousing Sizes?
derf
13
LA
Anyone know the bellhousing size? Are the Gas powered gen heads exactly the same as the Diesels in 3kW size?
Beerslayer
55
Tualatin, Oregon
If you have one taken apart, I saw a chart the other day I could re-find that tells how to determine the SAE bellhousing size by the measurements.
Edit: I refound it
This link is dead
derf
13
LA
I should have my 016B/Yanmar apart soon. I'm thinking about putting a larger head on the Yanmar. They put 7HP Yanmars on 3kW units and mine came with a 10HP so I'm thinking it can turn a 5kW head easily. I'd love to try a MEP-017 head if I could find one cheap enough.
Either way, I should have a good 3kW head for sale/trade soon.
panzerwillie
110
miami florida
I did that several years ago, i which i had the patiences or the time to do it, i made a adaptor here are some pictures , i posted the complete build in smokestak , the good all days,,DSCN4800.jpg
derf
13
LA
I searched smokstak but I couldn't find much info. What kind of adapter did you have to make and was it difficult? Did you start with a Yanmar with the Martin Diesel adapter?
derf
13
LA
OK, I found your adapter pics. My Yanmar already has an adapter for the 3kW head. Did yours have the same adapter? I'm wondering if the 3kW head and 5kW head might have the same bellhousing pattern. Anyone know?
See attachment. I think that is what I have coupled to the 3kW head.
panzerwillie
110
miami florida
Can't find the ones of the complete unit on the load bank up to 52 AMPS at 120 volts but smooth for a hour
or so, the YANMAR engine its awson , i even had the factory inclusure but sold it before i got to put it on, hope
this pictures help you:)
derf
13
LA
Excellent. Thanks for the pics. I may do the same thing. I may be getting a Gillette head, though, so I may use it as it would be much easier to adapt being a two bearing head.
I was hoping the 3kW and 5kW MEPs had the same bellhousing pattern, but you confirmed that they don't.
panzerwillie
110
miami florida
I did a few like that with dual bearing and a coupler work good especially that i belive the shaft on that yanmar is 1", if in diameter, if you deside to sale the bell housing flywheel and adaptor i would be intrested,
derf
13
LA
I almost certainly will sell the bell/adapter and most probably the gen head, too. I just can't see wasting a 10HP Yanmar on a 3kW head. I've had a few 5HP Yanmars but I haven't found any used 7HPs, yet. The 7HP is good for a 016A or 016B or 701, IMHO.
I bought a Homelite 6kW today for $50 for parts but it ended up just needing some cleaning and tinkering so it is whole and running fine now. I'm a little disappointed that it ran because it has a nice tank, frame, and components. But, I can't make myself scrap a perfectly good generator when there are so many out there that are already beyond reasonable repair. It was made in China, the typical Honda Clone 13HP motor. I would consider it a decent unit quality wise but compared to a MEP unit it is junk.
derf
13
LA
Does the Yanmar suck from the tank OK or did you need to use a pump other than the injector pump?
panzerwillie
110
miami florida
I use the electric fuel pump that was in it from the factory ,i t had 2 one for auxiliry tank so remove it and keep one
, it needed a battery for the electrick start but would start on the cable very easy, everything work like the factory
thanks
