- 3,613
- 5,258
- 113
- MA
Have you ever seen this load work properly, or did you just acquire it? Rebuilt or not... those mufflers are often caked with crap from improper use. I would put a can of seafoam in the tank and put small amounts of load on the machine over a few hours, to see if you can get it up and moving in the right direction. It has taken me 6+ hours of stepped load to clean out sets before. I am about to crack into a new 802 with what appears to be molasses on the exhaust pipe (and nicely gluing the plate and exhaust gasket in place when the roof came off).
As for the oil pressure gauge concern... have you tested to ensure its wired up properly (compared to the wiring diagram), is voltage present at the rear of it? You have pressure (as far as the manual dial and LOP switch are concerned)... so either now its a dead gauge, or a wire issue.
