MEP 831 FAQ for owners or potential buyers
Guyfang
22,227
Burgkunstadt, Germany
I might look for them, if I have a bit of spare time. What have you done to try and find them, so I do not reinvent the wheel, so to say.
OverkillTASF
Central Virginia
I looked through C-1 (Repair parts and special tools list) of the manual and couldn't even pin down the part numbers... but went through again and found that the whole stud (with hardware) is part 11, NSN 5940-00-234-3383. But from there.... Web searches feel like they're in spam-land, nothing appears in stock (even supposing the websites are legit, and I don't have experience in this realm), and there's nothing on EBay.
I could rig something together with COTS parts but I like the original setup and would like to match it!
Guyfang
22,227
This load terminal/ground stud has been used on Army generating since the early 70's. I know that Cummins sells it. I will try and look in the morning for another supplier. There are about 4-6 part numbers if I remember right.
Guyfang
22,227
These companies supplied the lugs to the Army.
44940CUMMINS POWER GENERATION INC. 1400 73RD AVE NE MINNEAPOLISMN55432-3702UNITED STATES
79343SCIENCE APPLICATIONS INTERNATIONALCORPORATION 155 PASSAIC AVE FAIRFIELDNJ07004-3561UNITED STATES
93568HARSCO CORPBMY-COMBAT SYSTEMS DIV YORKPA17405-1512UNITED STATES
93742DRS CONSOLIDATED CONTROLS, INC. 141 NORTH AVE BRIDGEPORTCT06606-5120UNITED STATES
Guyfang
22,227
Try writing this company a mail.
Give them this tech data:
WIDTH ACROSS FLATS0 3/4 INCHES
OVERALL HEIGHT2 51/250 INCHES
MAXIMUM HEIGHT ABOVE MOUNTING SURFACE1 51/250 INCHES
ELECTRICAL INSULATION FEATUREUNINSULATED
MOUNTING METHOD STYLESTUD
MOUNTING THREAD DIAMETER0 39/125 INCHES
THREAD LENGTH1 INCHES
BASIC SHAPE STYLECOMPRESSION
MOUNTING THREAD SERIESUNC
CONDUCTOR ACCOMMODATION TYPESPLIT BOLT W/O SPACER SINGLE END
NUT WIDTH ACROSS FLATS0 3/4 INCHES SINGLE END
MATERIALCOPPER ALLOY OVERALL
OverkillTASF
Central Virginia
Thanks for the specs and whatnot for the nuts. Unfortunately the only place that returned my RFQ for 3 nuts came in at $100 each.
Oof.
Probably gonna contact McMaster Carr and see what the thread is on some of these.
Guyfang
22,227
Indeed! That's just what we did. Ordered new hardware and just took the nut off. The only time we replaced a load terminal was when the threads were stripped. At that price, you could order on, just to see if it works.
OverkillTASF
Central Virginia
If its just the hardware... maybe you just buy something like this and steal what you need:
Edit: Just providing ideas... not sure this is a direct cross for the parts you need.
Yeah, that's what I'm doing. I skipped McMaster though.... I ordered some Gardner Bender "split bolt connectors" on Amazon. The GSBC-4 connector nuts are sliiiiiightly too small. I've ordered some GSBC-3's and GSBC-2's - will see if we luck out on the threads and the thickness of the slot. I don't have high hopes really.
OverkillTASF
Central Virginia
None of the Gardner Bender split bolt connectors have a compatible nut.
bcheval
11
Ft Worth Texas
This is all great info. Thank you, guys.
I am having a problem with my 831A. The engine is running well. However, it will only charge the lugs in when I activate (Battle Short) and then close the interrupter. If I start the unit and try to set the interrupter without the Battle short on, the lugs will not charge.
Any ideas?
