Mep Fan
- 7
- 3
- Warren Co NJ
Unfortunately my gen set has become a victim to a mouse nest in the bottom of the control box. At first it tripped a fuse and shut down but I then reset it and noticed smoke from the control box. I then shut it down to find a nest at the bottom of the control box. I removed the nest and found one damaged connection, a few wires charred on the outside but not all the way through. I repaired the damaged connection and started the gen set only to find that it creates power (at the convenience outlet) only during the flash of the gen-set. Once the start position is released the power drops off. I have read quite a bit on here about the same issues, I am mechanically inclined but not super familiar with this type of troubleshooting problem. I was thinking that the voltage regulator was bad and had replaced it with the help of Kurt from this forum to no avail. I did notice that there is a loose terminal on top of the control box that will not tighten all the way? Not sure where to get one of those either or even if replacing that is worth it? I really don't want to give up on this set just yet, it has worked flawlessly for over ten years and it still runs great! Any help would be greatly appreciated! Thanks, Perry
