ToddJK
- 4,490
- 113
- Sparta, MI
Yeah, still running the fdc for now. For filtering, I use 2 different filter socks that's meant for petroleum products, a 50 micron and a 10 micron. The 10 takes much longer and I only use it if the oil seemed really dirty. Otherwise I primarily use the 50 micron, I figured the fuel filters on the truck will catch the smaller stuff and I plan on changing those every so often anyway. I also throw some magnets in the filter sock to catch some metal if any.So are you still running with your FDC or have you deleted that? What are you doing for filtering that waste oil? I was thinking about a set up for waste oil treatment. Maybe just pumping it through a series of filters from a collection tank to a clean oil tank. What do you do?
My jet fuel is in a big tote, but I filter that through the sock into a 55 gallon drum I got from work and then pump that into the fuel tank. I suppose you could use a couple drums and filter from one to the other using a smaller filter, but I'd definitely invest in a nice pump, air or electric, I use a hand crank and my arms get tired after a while.
