Missing jack and tools
blutow
498
Austin, TX
I think I'm down to my last "missing" parts on my m1123. My truck has the jack storage compartment under the hood, but I'm missing the jack and whatever tools typically go with it.
I found lots of scissor jacks available on ebay, most come in a kit. See pick below. Is this the kit I need? Does everything fit in that compartment under the hood or just the jack? It looks like these were often stored under the seat, so I'm not sure if there are different versions based on model of truck or storage location. I don't need one of the big fancy bogart versions, I'm hopeful it will never get used.
Coug
4,162
Olympia/WA
That looks like the one I have in my M1123.
It works really well. One piece of advice I got about them was to run a ratchet strap around the outside of the case to prevent it from coming open when you are driving, as that leads to bad things happening to your truck.
blutow
498
Austin, TX
thanks. good tip on the ratchet strap, those clamps don't seem too secure
