MISSION COMPLETED: On the road, moving to Springfield Arkansas
dmetalmiki
2,026
London England
Start from scratch.
Battery + To Starter switch/solenoid. to starter motor.
Battery- earth.
Link from 'Governor' goes to throttle linkage.
A Spring (!) goes from throttle linkage to................Anywhere, With a little tension on it. (A LITTLE! at closed throttle).
Wire? From the contact points goes to a battery + through a switch.
If A magneto, Clean and adjust the breaker points.
Some fuel, Some oil. (Bow before it)...nahhh...A KICK!
brm brm brm......
Hope this helps.
I would sell it for parts, and grab a cheap ex military Onon 6000 W. Generator or similar that RUNS personally.
779
20
Springfield AR
Here's the pics and videos it's a real mess have a lot of work to do.
20
Springfield AR
Sorry didn't load.
20
Springfield AR
Ya been working sun up to sun down getting van ready. I may have to find another cheap generator if I can't get it to run. I'm only worried about as far as house goes setting a new power pole and installing service boxes. The rest is easy.
779
20
Springfield AR
I'm moving right along on the van I got the rear end back together and have the back brakes finally done what a PITA they were. I also got the generator going thanks to my step dad's 18+ years in the Army so a huge thanks to him for his help. Again thank you all for the words of encouragement as I move closer to making the big move to Arkansas.
marchplumber
2,508
Peoria, Illinois
God speed on your endeavors!! Never hurts to ask the "Man upstairs" for assistance, I highly recommend it!! One day at a time!! One step at a time!!
779
20
Springfield AR
Well guys I finally got the van up and going today. I need to find a smaller carburetor for it a 500cfm Edelbrock to be exact. The original carburetor was no good and got a very good deal on an intake and carburetor but didn't find out till I got home it's a 750cfm way too big works real good but runs rich. I'll have to post a want ad and maybe post the 750cfm up for sale.
779
20
Springfield AR
Well guys got the generator running. One side of the 120v works and runs my circular saw. The other side is reading low 70ish volts and doesn't work not sure what to check. Haven't checked the 220 plug because fuse and holding cap are missing.
779
20
Springfield AR
Well just got off the phone with my step dad and he walked me through the wiring we came.to the conclusion that maybe that 30 amp fuse has to be in place in order for the other 120 plug to work being that each side of the 120v is wired to the 240v and only 2 of the 4 pronhs had any voltage.
779
20
Springfield AR
Ok guys the 500cfm Edelbrock AVS carburetor came in yesterday. So just waiting on the heat soak base gasket. All that is left is the muffler and the door handle and window crank for Drivers side and van should be done. I'm gonna post up the other carburetor and some deuces parts I have sometime today.
779
20
Springfield AR
Ok guys all that's left with van is starter and muffler. We are packing my M105a2 trailer this weekend. Then my truck before we leave. So far things are going well. I should be leaving in about 2 weeks give or take.
779
20
Springfield AR
Ok guys got van up and going for the Miss. I will need to check sending unit as gas gauge quit working. I also got the generator working good and still have low voltage even with the 240v fuse back in. It was reading 90v but wouldn't run anything. I was able to run my small fridge tv my work lights and circular saw on the one plug at the same time so I think we can manage. I should be leaving just after Easter. I still have to put a tag light on my M105 and caulk my windshields and add my remote brake fluid reservoir. Then finish loading trailer and truck.
779
20
Springfield AR
Ok guys I figured I'd put this out there for those interested in the parts I'm selling I have no problem delivering along my planned route if need be. It would help my move and house repairs.
