Modify and build my m998
Action
1,552
East Tennessee
5584151 and 5514852 are the pieces to make the door jamb between the fenders and sponsons. Use the factory parts and maybe it will fit better?
TOM R
81
sewell n.j.
So the rest of the bolts down the bed sides, manual says 1/4-20 bolts, holes in sponson are too big even with washers, is that size a typo?
TOM R
81
sewell n.j.
Today's progress , picked up the windshield frame from welder, he put the military roof mount tabs on that hpg sells
Driver's radiator armor I got from eastern yesterday is installed
Picked up a used sponson from eastern with missing rear cone ,removed cone from my damaged one just to realize the cone is damaged ugh, radius is flattened some, we made some attempt at massaging the radius but even with a rosebud it's slow progress
Got the center pipe and the driver sponson noches up for now
Center pipe I got 2"OD .120 wall mechanical tubing figure that should be sufficient since it much heavier wall then the sponson pipes20210311_181242.jpg20210311_133707.jpg20210311_181321.jpg20210311_181344.jpg
TOM R
81
sewell n.j.
Today's progress the cone I needed to use was deformed with a flattened radius, after several heat and beat test and reheat beat and test fit cone is welded on and the sponsons are both mounted with the center pipe in place we will try to dolly it smoother before painting and I need seam sealer for the seam
Now when we are all done do I do the entire perimeter of the sponsons with silicone or something because those gaskets are not gonna keep out anything
Action
1,552
East Tennessee
Did you install new gaskets? From memory, the gasket is slightly taller than the spacers. Slantbacks leak. Make sure your heater works good to keep the windshield fog free in the rain.
TOM R
81
sewell n.j.
It opens and closes perfect that's the odd thing
I'm thinking I made the center pipe too long keeping that driver sponson a little off but noone wants to tell me how long that center pipe should be so I measured and guessed
TOM R
81
sewell n.j.
So measuring the roof mounts and then the mounts on the windshield frame and sponsons, it appears the passenger sponson is forward 1/4" then I saw this where the seats being held off the body by the sponson
Now I can probably get that sponson back the 1/4" but that's going to throw off the hatch even worse since the rear pins don't adjust20210315_134315.jpg
