Mrap dome light nsn 6220-01-556-5569
tagtech
Dallas, TX
We are looking for any technical manuals and any info. on which battery can be used in this dome light. Thank you in advance for any help you can provide.
I am seeking information on the following:
This is for NSN 6220-01-556-5569
Rectangular Dome Light
  • What is the correct PIN OUT of the three pins of the connector on the light housing?
  • What is the correct voltage of the internal battery?
  • What is the part number of the internal battery?
Any information you can provide would be greatly appreciated.
Intelligent Dome Light System
Manufacturer – ELTAM
US Patent Number 7429122
Navistar P/N 3825157C91
LIGHT, FRONT, CREW
(Retangular)
SMR CODE PAFZZ
CAGE 338X5
PN 3825157C91L
Manufacturer Information
3112796C91L 338XS Navistar Defense LLC
3825157C91 338XS Navistar Defense LLC
3825157C91L 338XS Navistar Defense LLC
5350000039-00 338XS Navistar Defense LLC
IDLS260 0813A ELTAM - EIN Hashofet
IDLS260 SAR77 ELTAM EIN Hashofet
LIGHT, REAR, CREW
(Round)
SMR CODE PAFZZ
NSN 6220-01-563-9517
NSN 6220-01-556-3938 (Alternate)
CAGE 338X5
PN 3825156C91L
265WG0219C2A003 LED
END ITEM IDENTIFICATION 2355015524677
INC 04451
Connector on light housings
Amphenol
97B-3103E-10SL-3P-622 1623
TM 9-2355-106-23P
Technical Manual – MRAP
https://dps.georgia.gov/sites/dps.g.../site_page/TM 9-2355-106-23P MaxxPro Base.pdf
tagtech
Dallas, TX
tagtech
Dallas, TX
Here is the information off the Female connector that goes from the wiring harness into the male connector on the following lights.
The below listed connector will work on the following lights:
#1 – Round Dome Light
6220-01-556-3938
P/N 265WG0219C2A003
(Round Dome Light)
((Two male connectors 180 degrees apart on major diameter.))
#2 – Rectangular Dome Light
6220-01-556-5569
P/N 3825157C91
(Rectangular Light / with mount / Jerk and run)
((Has one male connector on opposite end of light controls))
Connector female
ITTC 1247 7524125 CA3106E10SL-3SBF80
Female connect is part of wiring harness listed below.
6150-01-568-5809
338X5
P/N 3113430C91L
HARNESS
CAGE 75059
SPE4A612M6342
DION DEFENSE GROUP
5255 FEDERAL BLVD
SAN DIEGO, CA 92105
WWW.DIONTRUCKS.COM/DION-DEFENSE
619-263-2251
URL verification on 4/4/2024 indicates domain DionTrucks.com is not a valid domain company may be out of business.
Google search 4/4/2024 indicates Permanently Closed.
PRODUCT INFORMATION
Specification:MIL-DTL-5015 Type
Connector Type:Connector Circular
Connector Style:Plug
Contacts, # of:3
Contact Style:Pin
Insert Arrangement:10SL-3
Contact Size:3#15S
Insert Material:Neoprene
Amperage Rating:22A
Operating Voltage AC V RMS Max:500
Operating Voltage DC:700
Export Class:EAR / EAR99
RoHS:No
Weight (lbs):0.06596
Weight (g):29.92580
CA3106E10SL-3SBF80
ITT Cannon - CA-B Connector
CB 3C 3#16S SKT PLUG
RUGGED 5015 CONNECTOR FOR HARSH ENVIRONMENTS
ITT Cannon CA series MIL-DTL-5015 connectors featured a threaded coupling mechanism and are manufactured to MIL-DTL-5015 for use in very harsh environments. ITT Cannon CA Series heavy duty 5015 connectors were originally designed as aerospace components and are popular, cost-effective, rugged commercial and military connectors. Hundreds of contact layouts are available, including common 2-pin connector, 3-pin connector, 4-pin connector, 12-pin connector and 16-pin connector types. The ITT Cannon CA series is a waterproof 5015 connector that is completely sealed to withstand condensation, vibration, and flash-over.
https://www.farnell.com/datasheets/2100452.pdf
https://www.newark.com/itt-cannon/c...-SKU-Connectors-and-Cable-Connectors_TCPA-S44
Current Price on NEWARK is $44.77 ea, if I have not made a mistake.
KN6KXR
532
Felton, CA
There's not a lot I can help with without physically putting a meter to it and probing about. It's a nice package looks very well built. One can easily identify the charging circuit for the on board battery, drivers and such. It's a three wire plug but only two positions are used for a DC input. It's probably a 24VDC system as it would be brighter and more efficient but I wouldn't assume so. You can apply 12VDC without much risk as a test.
The connector looks correct. They aren't cheap but they are amazingly robust. If this were on my bench I would jump a power supply to it and start walking the TP's with a good DVM. You may need to access the other side to trace it out hopefully it's not epoxied in.
tagtech
Dallas, TX
Ok we might have a break in the case . . . .
Got another "Intelligent Dome Light System - LEBSI"
Manufacturer - ELTAM
NSN 6220-01-600-9425
BAE P/N 12510679
24 VDC single line input
Inside the unit we found a BACKUP BATTERY
The battery is marked
SANYO 3.6V
2500mAh
12/13 Lot#____
Amicell
It has the same exact two pin connector on the end which mates up to the 2 pin male connector coming from the board.
The battery pack actually feels like 3 AAA rechargeable batteries inside black plastic heat shrink wrap.
3.6 V makes sense due to the LED's in the unit.
Further testing will determine if batteries will take and/or hold a charge.
tagtech
Dallas, TX
SANYO 3.6V
2500mAh
12/13 Lot#____
Amicell
Amicell
19 Hayaalomim St.
Ashdod, Israel
Phone: 972-8-8561612
sales@amicell.co.il
