jimm1009
- 69
- 48
- Louisville, KY
I purchased my truck with MRAP 390 radial tires on it. What you fellow owners of such M35's with these tire / wheel combinations running in the way of tire pressure. Obviously any DOT compliant tire has the serial number with date of manufacture and max fill at max gross psi rating on it but what do you run for the normal truck with empty bed? I want to adjust mine for the best ride that you can get from the truck but do not want to harm the tires by under inflation. Jiim
