jimm1009
- 69
- 48
- Louisville, KY
I have a question for the group. When I purchased my M35A2 from the previous owner it had MRAP tires and wheels installed with adapter plates. The truck runs great down the road and at 2500 RPM and pure diesel I get about 63 MPH on flat or moderately sloped roads.
My ?? is this. My truck had the adapter plates installed on the inboard side of the front wheels with bolts pointing outboard. On both rear axles the adapter plates are outboard of the wheels with the bolts pointing inboard. I need to take all my wheels off and remove the adapter plates because they where installed without paint and are gently rusting. I will blast them, prime, and repaint. The plates installed inboard look better as you see more of the actual wheel. On the rear, obviously the backspacing would change by what ever thickness the adapters are in thickness, but would they not be better if mounted inboard? I know this more a question of looks but since I need to remove them for cleaning and paint I thought I would ask for opinions. I do not know positively who made the adapters and am waiting on an answer from the former owner to see if he remembers. Thoughts? Opinions? jimm1009 / aka Jim
